Post by CORE 4WD on Sept 10, 2007 18:34:01 GMT -5
Hey Billy it will be neat to see how that new engine performs on the dyno...I noticed today the piston's oil rings have finally worked in!
Post by broncobilly on Sept 11, 2007 19:20:23 GMT -5
? are you talking about?
Post by Chuck on Sept 12, 2007 15:57:12 GMT -5
You get any further luck on this? My overtime basically jumped up and swallowed me whole for a little bit. I'm going to sneak out early tonight for the meeting, and should finish the last of it Friday, so my schedule's starting to look a whole lot better.
Post by CORE 4WD on Sept 12, 2007 21:25:55 GMT -5
The exhaust was smoking a wee bit but now it is cleared up. I'm assuming the piston rings have worked into the cylinder walls kinda like brake pads to rotors... Let me know when you need a lift to Va Speed...
Post by CORE 4WD on Jan 16, 2008 21:07:02 GMT -5
Billy don't forget to post up carnage picks! If you want I'll post them up for ya. That chromo stuff going in yer D60 is the cat's meow...
Post by onewyr on Jan 17, 2008 18:08:39 GMT -5
did he ever figure out what broke we are still waiting, come on billy what is taking so long?
Post by CORE 4WD on Jan 18, 2008 9:26:02 GMT -5
3 kids keeps his spare time at a minimal for computer. . The inner driver side shaft twisted off where it necks down to the splines...
Post by onewyr on Jan 18, 2008 16:50:57 GMT -5
we need pics words no good
Post by broncobilly on Feb 3, 2008 20:42:00 GMT -5
Front driver side axle inner shaft snapped. Fixed that with some chromoly axles with super joints. Replaced rear 5 leaf pack with a 11 leaf super flex from Bronco graveyard. Rear yoke broke the ear which holds in the cap on the u joint, so I found the yoke with u bolt style rather than straps. Fixed a rear brake line with an extended stainless steel line.
Post by CORE 4WD on Feb 5, 2008 22:35:20 GMT -5
Whaddaya say we get that e-brake fixed up tomorrow?
Post by broncobilly on Feb 6, 2008 21:59:04 GMT -5
Dave and I started fixing the e-brake cable on the Bronco. Dave fabricated a new bracket to replace the one that was tearing off, and got that installed only to find that the 30 yaer old brake cable was froze up. Ordered that so the e-brake should be awesome. Thanks Dave for the on the spot fabrication work today and I'll try to get those hubs for you.
Post by CORE 4WD on Feb 6, 2008 22:25:46 GMT -5
Yea I'm glad we got that taken care of finally! That cable did seem pretty tight before, should work like a champ with the new one...
Dave
Post by CORE 4WD on Jun 3, 2008 21:01:35 GMT -5
Hey Billy bring your junk down here so I can weld up the muffler!
Post by broncobilly on Aug 2, 2008 20:18:47 GMT -5
Got a new cam made for what I am doing with the bronco and found out the exhaust was dry rotting my fuel filler hose and chunks were getting in my gas tank clogging my pick up. Had tank cleaned and steamed and she is running like a champ. ;D
Post by CORE 4WD on Aug 3, 2008 19:44:21 GMT -5
Hey Billy, get that Lokar cable and we'll stick that on and get you a little better throttle pedal feel. May have to play with return springs a bit. So am I gonna get a ride sometime? Let's keep off the Strip, though. I think she just wanted you to ask her if she wanted a ride.... ;D
