Post by rednblue on Mar 15, 2006 20:02:08 GMT -5
I got Blue home today, an 03 Rubicon List of obvious problems T-Case Drop Rusted Stabilizer Driveshaft Firestik antenna hitting tail light New Stabilizer
Post by What It Was on Mar 15, 2006 20:07:55 GMT -5
What Rubi's came with the air suspension?...
Post by IlovemyYJ on Mar 15, 2006 22:03:21 GMT -5
gary that you...i think i reconize the posion spyer rocker guards
Post by Chuck on Mar 16, 2006 11:10:01 GMT -5
... Driveshaft... Yeah, that's definitely off by just a few degrees! ;D Looks good, though, should be a sharp ride once you get it cleaned up a little!
Post by Jim63 on Mar 16, 2006 12:46:00 GMT -5
looks good!
Post by What It Was on Mar 16, 2006 12:52:40 GMT -5
drop the pinion about 3-5 degrees or so.. and you'll be alright
Post by bensredyj on Mar 16, 2006 13:51:49 GMT -5
Shaft seams a bit LOONNG their with no Compression, is that stock? Looks like a FIXRUPR
Post by CORE 4WD on Mar 16, 2006 22:22:43 GMT -5
... Driveshaft... Yeah, that's definitely off by just a few degrees! ;D Looks good, though, should be a sharp ride once you get it cleaned up a little! Are the upper control arms adjustable? Looks like it's got RE components on it? Great platform to tweak out!
Post by rednblue on Mar 16, 2006 22:30:30 GMT -5
Jim63 - Thanks, Your's is looking good too.
Fife - It's Way off, I got to put the HF angle finder on it.
Bensredyj - I'm not sure if it is the stocker or not. I gotta take a day and pull it out.
CORE4WD - Yes it has a 4.5 inch RE lift with lower fixed and Upper adjustable. I think I am gonna scrap the upper adjustables for my next mod. I need to tweak it out on a RTI Ramp! Once I Git R Dun.
Post by Jim63 on Mar 16, 2006 22:35:20 GMT -5
so when is that anti rock system going on?
Post by rednblue on Mar 18, 2006 23:17:19 GMT -5
so when is that anti rock system going on? Current plan is to get started Sunday. I am going to pull the front bumper and winch off first, then I will put the antirock in. Might take me a couple of days. I am going to inspect the suspension and get up under their and clean up all the rust. I am going to have blue under construction with more mods to come in April. I got a stack of parts waiting on me in the garage and I am waiting for some parts in the mail. I will be pulling some parts off and selling them so that I can upgrade.
Post by Jim63 on Mar 19, 2006 12:56:18 GMT -5
sounds like fun!
Post by A "CJ" on Mar 19, 2006 18:24:19 GMT -5
Yeah, that's definitely off by just a few degrees! ;D Looks good, though, should be a sharp ride once you get it cleaned up a little! Are the upper control arms adjustable? Looks like it's got RE components on it? Great platform to tweak out! Now I don't know much about the rubi's but is that a spacer at the tcase side and if so can it be removed to get the correct fit for the driveshaft. I agree with Ben, way LOOOONG there. Nice rig, tim
Post by rednblue on Mar 23, 2006 21:49:25 GMT -5
I pulled the bumper and winch off, removed the shocks, disconnects, rear adj control arms, and front adj control arms. I can get a better look from the front of the jeep and I noticed Slightly bent Transfer Case Skid. Going to do more dissassembly this weekend, Waiting and searching for parts right now.
Post by rednblue on May 3, 2006 15:22:07 GMT -5
Started the install today. OME Shocks and 4.5 inch springs with new control arms upper and lower.
