Post by KarlVP on Feb 3, 2008 23:49:45 GMT -5
Finally get to do some maintenance and work on my Jeep. Thanks to TommyBuilt Fab out in Sultan, WA for letting me use the shop to work on my Junk. First order of business was to get the heep running right again. This required a cooling system replacement. Also diagnose and replace some of the parts in the CCV system (lots of blowby, thought it was the pistion rings). Got that taken care of, now time to work on the suspension. Front axle out of the rig, time to replace the bushings, ball joints, and chek the diff lube. (Thanks FiFo for the loaner tires to get things in progress) Another pic of the front suspension gone. Old suspension bracketry gone, getting ready for new TommyBuilt Fab long arms. I designed the suspension I want in the rig, but I'm having Tom weld it in. Same as I did when I built the cage. I can bend tube and design angles, I just dont trust my welds that much. Additional list of stuff to get done. Completely flat belly pan. Raised TommyBuilt Fab motor mounts and tranny mount. Replace bushings in rear suspension. And some "body work" and additional frame to body strengthening.
Post by LILREDCJ6 on Feb 4, 2008 5:30:36 GMT -5
Karl what was the cause of the blow by?
Looks good and cant wait to see it finished.
Post by KarlVP on Feb 4, 2008 11:01:20 GMT -5
Karl what was the cause of the blow by? Looks good and cant wait to see it finished. Tony Clogged vacuum line on the CCV system. That and the air intake silencer box thingy was cracked and sucking oil from the CCV.
Post by KarlVP on Feb 16, 2008 23:19:20 GMT -5
Cutting out the new flat belly pan. New Radius arm mounts to tack the frame. Putting the new lower control arms in for the first mock-up. Tom welding the bushing end on the new lca's. And the lower arms in place. Tomorrow we start on the upper links.
Post by 87B2XLT on Feb 17, 2008 20:38:38 GMT -5
Looks like it'll be a lot better when you're done, Karl... I know you're itchin' to get it back on the trails ;D
