Post by smrflng on May 18, 2009 11:15:44 GMT -5
Dragging home the next project this afternoon. And yes its another yota. The porn site is a wonderful thing.
Russ ;D ;D ;D ;D
Post by ex-tbd85hilux on May 19, 2009 3:06:06 GMT -5
Details... and Pics... Quit teasing!
Post by smrflng on May 19, 2009 5:29:40 GMT -5
Just for you Paul, Its an '85 pick-up with a blown up motor. Gonna take most of the stuff out of the 4-runner and put into truck. I will try and get some pictures up this afternoon after work.
Russ ;D ;D ;D ;D
Post by ex-tbd85hilux on May 19, 2009 6:06:18 GMT -5
Man Russ... you swap those parts over more often then I get vehicles... What's wrong the 4runner? Did you scratch it? ;D Paul G.
Post by smrflng on May 19, 2009 15:24:29 GMT -5
Cheaper to swap parts than to covert 4-runner to solid axle.
Russ
Post by JeepCJ5 on May 19, 2009 15:32:53 GMT -5
Cheaper to swap parts than to covert 4-runner to solid axle. Russ Old Chinese proverb, or did you make that up?
Post by smrflng on May 19, 2009 15:37:47 GMT -5
Actually I think Denise made that up, or at least thats what she said when she told me that she controlled all of the money.
Russ ;D ;D ;D ;D
Post by Deleted on May 19, 2009 15:45:46 GMT -5
Someone please take away Russ's emoticon privileges. ;D ;D ;D
Post by smrflng on May 19, 2009 15:52:39 GMT -5
Keith you're funny.
Russ ;D ;D ;D ;D
Post by Jesse Schneirla on May 20, 2009 7:22:15 GMT -5
Between Russ building Yota's and Brian building Ford's we will always have something to watch being built. But at lest Russ wheels his a couple of times before he tears it down and starts again. I just wish I had the time to keep all of our running. Getting the parts is no problem, getting the time to install them is. I have had the parts to fix Sandy's now for at least a month. What a slacker!
Jesse
Post by smrflng on May 20, 2009 11:22:35 GMT -5
Just remember Jess, you said that you were a slacker. But I know you will get more done when the new garage gets built.
Russ ;D ;D ;D ;D
Post by smrflng on May 20, 2009 20:08:17 GMT -5
Its the first time I have seen a see through engine. #3 rod made a hole in each side. But then its just about ready to pull out.
Russ ;D ;D ;D ;D
Post by Jesse Schneirla on May 21, 2009 12:24:15 GMT -5
Yah, that's my story...I would get things fixed and on the road faster if I had that garage and the hydraulic lift. Someone tell Sandy that please!
Post by ex-tbd85hilux on May 22, 2009 0:56:42 GMT -5
Its the first time I have seen a see through engine. #3 rod made a hole in each side. But then its just about ready to pull out. Russ ;D ;D ;D ;D May want to contact Toyota on this one... Had a buddy 8 or 10 years ago had is replaced under warranty by toyota for the same problem. They flew one of the original engineers out from Japan to look at the block because none of the techs at the dealership had ever seen it. Toyota Japan determined that it had to be a fault in the casting of the block and replaced it for for free with almost 350K miles on it. Of course he was the original owner and beat the hell out of it... Paul G.
Post by smrflng on May 26, 2009 16:52:31 GMT -5
This was some sort of reman engine. Has serial number on the side of it, but no company name. It kind of looks like an LC Engineering motor they way it is painted. But I amnot sure how they number their rebuilds.
Russ ;D ;D ;D ;D
