1TONCJ
New Member
Jammin Out
Post by 1TONCJ on May 26, 2009 16:08:16 GMT -5
Finally have my business up and rolling, so I can finally get back to getting it back on the road! Any suggestions are very appreciated! Haven't had the chance to cut it and bolt on the comp corners yet, and will hopefully have an entire saturday here soon to weld the cage in. Sitting on 38's now, will hopefully still be able to fit them when I take that goofy body lift off. Has full witdth kit from BTF and new 14 and Dana 60. (thanks DRMO!)
Post by newt on May 26, 2009 17:43:47 GMT -5
Don't make the mistake I made - use the comp cut corners as a template. I cut too high and the pinch weld seperated. You'll have plenty of room for the 38s, your width will give you even more room than I have, and I clear 38s easily w/ stock waggy springs over the axle and cut fenders. I wish i'd left enough in the rear to mount a normally shaped flare ...
Adam
