Post by OFBY&4 on Sept 6, 2010 12:10:40 GMT -5
Anyone have one of these. My compressor is squeeking a little and I thinks it's the clutch. Still researching on whether it's worth replacing the clutch or whole unit. When it does run it runs cold.
oh yea.....97 tj 4.0
Post by A "CJ" on Sept 6, 2010 13:03:35 GMT -5
Should be able to rent from Auto Zone or Advance... worth a try.
Post by gtmud on Sept 17, 2010 17:19:32 GMT -5
Squeak, does it go away when you turn on the A/C? With the engine running try and spray a SMALL amount of WD40 on the belt as its rotating, if the squeak stops then you will need to replace your belt. Usually if you have a squeak coming from teh A/C compressor it could be the bearing that the pulley rids on.
Ken
