Post by thinblueline on Dec 30, 2010 21:03:08 GMT -5
looking for someone to install a body lift for me. i have the lift and the new body bushing. its on a 95 full size bronco, i just dont have the place to do it now that i moved. i would like to do as a work party weekend, i will supply food and drinks or i will pay someone if the price is cheap. my wife doesnt give me much money to put into my toy. i am getting ready to install the leveling kit on the front with the new shocks. anyone interested give me a call 757 769-9115 look forward to meeting new people and wheelin together. thanks mark
Post by rroadkilll on Dec 30, 2010 23:34:04 GMT -5
Where are you located???
Post by thinblueline on Dec 31, 2010 9:40:56 GMT -5
I am in Virginia Beach
Post by A "CJ" on Dec 31, 2010 14:54:07 GMT -5
The body lift is the easy part, relocating items like the radiator/AC condensor if equipped. Shift linkage, wiring and fuel filler neck are the PITA. I did a 79 Bronco and ran into all kinds of nickle and dime things. Even needed to weld new shift linkage extensions. What size tires are you going to run? Most fords except up to 35" tires with 4" - 6" of lift. Does that year of bronco have the TTB ( pivot in the middle) or solid front axle?
Post by thinblueline on Jan 2, 2011 19:25:12 GMT -5
Its ttb front end. i was told i just need to cut the fan shoud or move it down. not sure on the other thing. hope its not to bad i have had the lift for a long time just havent had time to do it. i will ask some of the guy on fsb what i need to do. i am also installing the leveling spring soon.
Post by thinblueline on Jan 28, 2011 10:52:50 GMT -5
I installed the leveling kit on the front now need to do an add a leaf in the rear. i have all the stuffto do body lift, blocks bolts steering extention. Not worried about bumpers right now going to build a set. The only thing I need to make is the fan shroud relocatin brackets. Shifter linkage is a cable no one has had any trouble with. Hope I can get time to do it soon.
