Post by bierburner on Mar 12, 2011 8:05:38 GMT -5
Well I was watching another new project JK video on You Tube and saw another possible location for the CB. One of the guys had it mounted in the passenger overhead. I thought that be a good idea plus he had his mic on a retractable lanyard hanging with in arms reach. The only down fall I saw with mounting it here is when the top is off. I have a few other locations in mind. Anyone have a CB mounted in there JK and happy with the location. Thanks for any input. Uriah
Post by ScramblerPat on Mar 12, 2011 12:10:37 GMT -5
I tried the lanyard idea and on the street it is great, but on the trail someone will get a concussion.
sandsquid
Wheeler
07 JK Unlimited, 83 CJ-5, 06 Commander Limited
Post by sandsquid on Mar 12, 2011 13:51:47 GMT -5
I mounted mine to the side of the center councel. I used one of the factory screws and meant to make a bracket like they sell in quadratec but never did. with just the one screw it fits snug and has not really moved. I used a 2 wire trailer plug from NAPA (I think) for power and ground incase I need to pull it out for any reason. Got the power from the ignition on plug in the councel. Right there at you finger tips, and the wires tuck neatly under the carpet. When on the trail I just put the mike in the cup holder.
Post by bierburner on Mar 12, 2011 15:46:37 GMT -5
I mounted mine to the side of the center councel. I used one of the factory screws and meant to make a bracket like they sell in quadratec but never did. with just the one screw it fits snug and has not really moved. I used a 2 wire trailer plug from NAPA (I think) for power and ground incase I need to pull it out for any reason. Got the power from the ignition on plug in the councel. Right there at you finger tips, and the wires tuck neatly under the carpet. When on the trail I just put the mike in the cup holder. Chuck I'll have to check out your set up one of theses days. Uriah
Post by Marshall on Mar 16, 2011 18:14:52 GMT -5
Ive got mine mounted in the same place as chuck, excepti have the bracket....works real well!
Post by joshbaker on Mar 28, 2011 10:41:07 GMT -5
the lanyard is called a gear keeper. I love mine in the dually. You can get at any truck stop for around $10.00
