Post by Sticks on Aug 5, 2011 10:18:12 GMT -5
Hey all, Been a while. Enterprise deployment, getting ready to move to Japan, tons of fun. Changing the shocks out on my daughters 1999 XJ. The upper mounting bolts for the right rear ( and I''m sure the left will get broken too) ..that go through the lower body are broken basically flush with the sheet metal. I thought those holes were not threaded and I could punch them out but I think the nuts on the inner/upper side are tack welded...as well as the holes being threaded.
I do not know what to do. Tried to get a drill bit on them, no luck. Air hammer?
Yikes....smh.
Andy
Post by Deleted on Aug 5, 2011 11:08:54 GMT -5
Not sure what an XJ looks like in that area, but I had to do this on a TJ once. Ended up using a hole saw on the floorboard above the area for access. I used a dremel because it was small, and an air chisel to remove the welded nuts the rest of the way. Then used some paint around the edges of the hole I made and plugged them with plugs from Lowe's. It was either that, or remove the gas tank for access to the welded nuts.
Post by CORE 4WD on Aug 6, 2011 11:48:52 GMT -5
The ones I've had to do I drilled out and then re-tapped to clean up threads.
Post by stumper92 on Aug 6, 2011 22:05:00 GMT -5
I had the same thing happen. I ended up doing the same as Fromme. XJs are notorious for the rear shock bolts breaking off.
Post by onzrocks on Aug 7, 2011 8:13:42 GMT -5
Post by Sticks on Aug 7, 2011 20:00:13 GMT -5
I didn't have the time or tools to get them drilled out. Kempsville auto care center took care of it. Drilled em out and cleaned up, replaced the shocks for relatively cheap.
