Post by splogue on Aug 14, 2011 15:19:12 GMT -5
I have a 4.0 hooked up to a T-5 and the clutch fork will drop/fall out of place after I push the pedal in a few times. This causes the Push Rod to come out. I have yet to put any springs on the fork since I cannot figure out where the opposite side attaches.
Is the fork supposed to drop? If not, can I fix it with our pulling the engine? will a strong spring hold it up? Can someone help a brother out and take a few PICS?
This is the last major thing I have to fix before I get it on the road and FINALLY DRIVE IT.
THANKS
Sean
Post by newt on Aug 14, 2011 15:53:48 GMT -5
Picture please.
Post by A "CJ" on Aug 14, 2011 19:21:48 GMT -5
Here is a little pic that might help..... pc 14, along with 15 and 16 hold and support the fork to the bell housing so it doesn't fall off, I believe that is your question. Bad news, you will need to drop tranny to get to this...The pic above shows older CJ style stuff, if your running external hydraulic slave cylinder to a clutch fork would think it should be close to the same. tim
Post by splogue on Aug 23, 2011 9:42:37 GMT -5
Post by What It Was on Sept 22, 2011 14:45:25 GMT -5
silly, I have tons of clutch parts, linkages, adjusters, springs etc... lol. You need some spares? ;-)
