Post by bensredyj on Jul 14, 2014 11:29:18 GMT -5
So having some issues with a late model warn 9.5 Ti winch, the brake decided to quit holding, cable spools back out, then the solenoids started clicking... So how do I tear this thing apart and find parts before the annual? Thanks Ben
Post by toynrnd on Jul 14, 2014 12:33:47 GMT -5
warnserviceparts.com/ I'll check and see if I have an exploded view of the 9.5 ti. Have you taken it apart yet?
Post by gte718p on Jul 14, 2014 18:47:22 GMT -5
I'll take it off your hands so you don't have to deal with it. . Most likely with the brake cracked or the break springs gave up. The are relatively easy to take apart with Allen screws. You take the fancy top part off, unscrew the cross beams and basically pull it apart. It should separate relatively easy into the motor side, the spool, and the gear side. The parts of interest to you will with be in the spool, or attached to the motor. It is most likely either part 13 or 19 on the exploded view.
Post by bensredyj on Jul 14, 2014 20:33:44 GMT -5
I havnt taken it apart yet. I heard that warn has a replacement upgrade for the brake. Will need to take it off jeep to repair. Contact warn for parts?
Post by toynrnd on Jul 15, 2014 4:53:51 GMT -5
Any of their service centers will have/can get parts. Check that link.
