Post by onewyr on Aug 28, 2009 18:40:36 GMT -5
Me and Josh went and retrieved my new project yesterday, and figure the odds I got another BroncoII it is an '86 so I will not need to do a front clip swap like I did on the last two trucks but that means I will have a wiring night mare. It shouldn't be to bad I have been comparing the wiring diagrams from the 86 and the 92 that the 4.0 came out of and it seems like i have about 10 or 15 splices to make so that the new motor will work with the old harness. The PO has already pretty much gutted the truck including the top back half of the truck so it is a choptop now so cleaning up the cuts and adding a cage are at the top of my things to do list. I worked a deal with Josh today to get my 8.8" rear back in exchange for the set of wheels and tires on the truck. I need a new front axle though cause that d28 just isnt gonna cut it. Considering either a d30 from a xj and use the rusty's long arm kit or just going back with the trusty old d35 TTB (hell it never let me down) . but anyways here is the truck and things to do.
Things to do
fix stress cracks in driverside floor board
remove the bs nerf bar from the driverside
fix the rockerpanel on the passenger side
I need to weld some sort of caps where the top was removed
weld a couple of hole that the PO put in the rear quarter when he tried to put a back wall in the truck.
take the 1993 up ranger tailgate off and put a 1980 up tailgate on.
coat the floor with something thick.
firewall repair rust
remove the 3" body lift and instal the 2" bodylift maybe.
add on to the front of the frame so I can mount a bumper ( for some reason some one cut the first 5" of the frame off )
after all that is done I will worry about a lift and front axle
I still have the motor and tranny from my ranger build so they will be going in and I will need to round up another manual tcase and axle.
I will definitely post more as I get stuff done or think of other stuff that I want to do
Things to do
