Post by ex-tbd85hilux on Jan 13, 2011 11:37:17 GMT -5
So what will be the weak link on the diesel? Drive shaft or tranny? I think the 1500 should be a truggy. Clutch... Possibly U-Joint... I think the clutch will give up the ghost pretty quick if he dumps it wrong. Paul G.
Post by Deleted on Jan 13, 2011 16:59:11 GMT -5
So what will be the weak link on the diesel? I'm thinkin it's gonna be the driver. ;D I'm wondering if he added up all the advertised numbers on the boxes (ricer style) to come to that hp conclusion, or is this a plausible claim?
Post by smrflng on Jan 13, 2011 17:42:29 GMT -5
Yep another black dodge to bounce off trees. Can I be the trail guide? PLEASE ;D ;D ;D ;D
Another question is that will the pullin truck hold together long enough to pull the black truck to oakrridge.
Russ
Post by joshsbetterhalf on Jan 13, 2011 23:54:21 GMT -5
Yep another black dodge to bounce off trees. Can I be the trail guide? PLEASE ;D ;D ;D ;D Another question is that will the pullin truck hold together long enough to pull the black truck to oakrridge. Russ My truck is NOT bouncing. At least hopefully not. This truck still will have to get me to and from work as LEGALLY as possible and I will NOT drive a dented up truck. So yes, Josh and I still have things to figure out as far as that goes. Before we worry about the 'pullin truck' holding it together, we've gotta get a gooseneck hitch put in it AND buy a trailer. So we will see... It will be, at a bare minimum, be going to Starr in March.
Post by joshbaker on Jan 14, 2011 15:01:15 GMT -5
Ok so to answer all the latest questions.
1 truck already has a pretty beffey clutch 2 driver can drive just about any rig he wants (class a cdl) 3 As for adding up number like a ricer yea ok. How bout we go to a dyno shop in bout middle of febuary ( that will give yall a nuff time to at least think about building a rig like the 3500) and see who has 500+ hp at the rear wheels. I for one know i will for the simple fact that the guy that im getting my numbers from (TRE diesel) Has built many a truck like mine and says 500+ will be no problem once he sets up the injection pump for the new stuff.
4 If you have doubts about me or the truck ill see you on the dyno or the strip which ever one you feel best at dont matter to me.
Oh and for all the naysayers out there just remember I have no problem building what i want. I do a heck of a lot of research before i do something.
Post by smrflng on Jan 14, 2011 15:28:33 GMT -5
Candace as long as you don't let Josh drive.
Russ
Post by joshbaker on Jan 14, 2011 15:48:01 GMT -5
who who who ill be the one driving at starr.
Post by joshbaker on Jan 14, 2011 15:51:31 GMT -5
So what will be the weak link on the diesel? Drive shaft or tranny? I think the 1500 should be a truggy. Clutch... Possibly U-Joint... I think the clutch will give up the ghost pretty quick if he dumps it wrong. Paul G. here is the clutch ill be putting in to replace the LUK Gold that should last a couple more years. Kenny's Pullin parts NV4500 SINGLE DISC KITS CLICK HERE FITS 1994-2003 5 SPEED 3800# DIAPHRAGM PRSSURE PLATE AVAILABLE IN 3 FRICTION MATERIALS FULL CERAMIC 550 HP (NOT FOR HEAVY TOWING) $500.00 Talked to the guy and for what i want to do the full creamic is the best for me.
Post by Deleted on Jan 14, 2011 16:26:14 GMT -5
Let's hook em up with a strap!
Post by ScramblerPat on Jan 14, 2011 16:32:20 GMT -5
here is the clutch ill be putting in to replace the LUK Gold that should last a couple more years. Kenny's Pullin parts NV4500 SINGLE DISC KITS CLICK HERE FITS 1994-2003 5 SPEED 3800# DIAPHRAGM PRSSURE PLATE AVAILABLE IN 3 FRICTION MATERIALS FULL CERAMIC 550 HP [glow=red,2,300](NOT FOR HEAVY TOWING)[/glow] $500.00 Isn't truck pulling "heavy towing" ?
Post by joshbaker on Jan 14, 2011 17:45:37 GMT -5
Let's hook em up with a strap! Sure why not. You use 2wd ill be in 2wd no weight in the bed. On dry pavement. Oh and since everyone knows what i got what u got??? And just fyi my turbo showed up tonight.
Post by ex-tbd85hilux on Jan 14, 2011 21:30:44 GMT -5
there is such a thing as too much power... Yeah it looks cool till a rear tire desintigrates or a NOT FOR HEAVY TOWING clutch explodes....
Research or not... There is a weak link in there someplace... And you are going to find it sooner than later... and odds are it's going to be expensive when it blows... Keep in mind... with gas engines horse power kills. In Diesels torque is the monster. So you will have a 550 HP engine... If my math serves correctly that's about 700 to 800 ft/lbs of torque. There are several components that are not rated for that much rotational force... Your transmission, u joints and rear axle shafts just to name a few.
Food for thought... and good luck.
Post by stumper92 on Jan 15, 2011 6:26:55 GMT -5
I would be happy to provide the field for this challenge. Calling all Oil Burners!
Post by smrflng on Jan 15, 2011 6:50:27 GMT -5
Sounds like fun. It will be a joy to see if parts go flying.
Russ
Post by Deleted on Jan 15, 2011 10:38:05 GMT -5
Let's hook em up with a strap! Sure why not. You use 2wd ill be in 2wd no weight in the bed. On dry pavement. Oh and since everyone knows what i got what u got??? And just fyi my turbo showed up tonight. No sir, there's no excuses. You either put your big boy pants on and hook up or you don't. Its not my fault you can't get the power to the ground. Tell ya what, you remove the outer dual tires and ill think about using only 2wd. I got nothing special. Just an old powerstroke with about 330 hp. I do have some 50 hp injectors to put in but ill still be well under 400 hp. But I can use every bit of it. Until my transmition breaks.
