Post by PaulC on Jan 29, 2013 19:14:20 GMT -5
What no picture of it installed?!?
Post by Deleted on Jan 29, 2013 21:21:37 GMT -5
Post by newt on Jan 30, 2013 21:47:06 GMT -5
Look like there is room to get your tie rod on top of the stock knuckle too.
Get a drive shaft in there and lets go optest it.
Post by Deleted on Jan 30, 2013 22:58:49 GMT -5
There might be room but I'm not even going to worry about that right now. The picture angle is deceiving. And for the last time I can't just throw a front driveshaft on there. A t-case skid has to be fabricated first.
What I do need is a cool hood ornament. The OP drilled a huge hole in the front center of the hood and had some ancient GPS receiver mounted there. I was just going to put a plastic plug in the hole but then I figured a unique ornament would be way more fun.
Post by toynrnd on Jan 30, 2013 23:36:21 GMT -5
Post by newt on Feb 1, 2013 6:24:03 GMT -5
Find a good manstang for the hood.
timbillyosu
A bad day fishing is still better than a good day working.
Post by timbillyosu on Feb 1, 2013 7:31:53 GMT -5
What I do need is a cool hood ornament. Pfft Hood ornament? I will raise you a Carstache! www.carstache.com
Post by ex-tbd85hilux on Feb 1, 2013 13:40:26 GMT -5
I opt for the flying pig
Post by newt on Feb 1, 2013 15:27:19 GMT -5
Post by PaulC on Feb 2, 2013 20:48:39 GMT -5
Post by Deleted on Feb 2, 2013 22:09:29 GMT -5
Post by Deleted on Apr 4, 2013 22:58:28 GMT -5
Had to remove two leafs from each spring pack. Now it will finally flex. It also lowered it to a more manageable height. I can get it in the garage now but barely. But then I had some terrible axle wrap. I torque arm kit from Ruffstuff Specialties did the trick. I also put on some newish Q78s. Should be all set after I figure out whether I have the necessary clearance between the right side muffler/tailpipe and the new torque arm I just installed. I may have to tweak the muffler location.
I don't know why but these photobucket pics do not show up for me on this forum. You'll have to click the links.
Post by stumper92 on Apr 5, 2013 4:10:51 GMT -5
Didn't work for me either...
Post by newt on Apr 5, 2013 6:09:37 GMT -5
The links don't work either.
