Post by 87B2XLT on Dec 6, 2008 23:37:29 GMT -5
Not even close to being done Dave! Are they ever? True, most of the time it's a work in progress between breakages... at least after you get it 'done' the first time, right? At least it's a lot closer than it was... shooting for a late Winter run or is it going to be Spring before it sees any action? Dave G
Post by CORE 4WD on Dec 7, 2008 7:46:52 GMT -5
Harold's Hiway in a couple weeks then Crozet in January brrrr maybe not! Dave
Post by greenbean on Dec 7, 2008 9:37:44 GMT -5
Dave glad to see the EB nearly ready to wreak havoc on the trails! Let me know when or if you go up to Harolds...I'd like to swing up there myself and do a shakeout. Also want to try and hit at least one day of that Jan Crozet weekend, I got an itch for some rocks!!!!
Post by CORE 4WD on Dec 7, 2008 11:58:35 GMT -5
[glow=red,2,300][/glow]It will be creating "Mayhem" on a trail near you soon....Harold's for sure....
Dave
Post by PaulC on Dec 7, 2008 18:38:52 GMT -5
Dave,
I think you need to change your Avatar to the picture of you and Alex in the Bronco, since you don't own the XJ anymore.
Post by CORE 4WD on Dec 8, 2008 21:07:32 GMT -5
Finally figured out where I wanted to mount hydraulic assist ram. Welds have a tight pass followed by a second pass. I suppose thickness (lack of) of cover will determine lifespan of tabs - The cover is 1/8", hopefully it will last until I can get a decent 1/4" wall or better cover. Dave
Post by FJ40Fran on Dec 8, 2008 22:34:12 GMT -5
Dave, you're going to have so much fun putting rock rash on all that new paint !!!! I can't wait until we you wheel that Bronco. I'll get you on my trailer just to get up to Crozet and flex it out.!!
Fran
Post by CORE 4WD on Dec 9, 2008 20:56:47 GMT -5
I'll take you up on that for sure Fran! You going up on the 18th of Jan? Ram is installed, just need to bleed it out- Steel run tomorrow afternoon for slider material... Dave
Post by CORE 4WD on Dec 16, 2008 17:24:06 GMT -5
Bronco's a driver now. Runs great. I'm working on rock sliders right now, then exhaust and front driveshaft so I can go play somewhere near and break in axle gears and stuff...
Dave
Post by CORE 4WD on Dec 19, 2008 10:02:48 GMT -5
More progress- Sliders are almost done- I'm using Summit 12" glasspacks because they're compact. Hopefully they'll sound good, too. Aaron at NAPA hooked me up with 10' of 21/4" exhaust pipe on the cheap as well- Dave
Post by CORE 4WD on Dec 21, 2008 18:14:01 GMT -5
Post by CORE 4WD on Dec 22, 2008 19:57:14 GMT -5
Post by 87B2XLT on Dec 27, 2008 0:09:37 GMT -5
Now that I've finally been able to see some of the pics I was being robbed of seeing due to the ship's proxy... holy sheep snot, that thing is looking good, Dave! Glad to see everything finally coming together Dave G
4x4x289
New Member
Design it for function. Make it simple & durable. Beauty follows naturally.
Post by 4x4x289 on Jan 5, 2009 0:55:12 GMT -5
Surfing the web tonight and ran across your thread. Nice rig. Keep up the good work.
Post by CORE 4WD on Jan 7, 2009 19:25:36 GMT -5
Thanks! Are you local? A couple EB peeps around here are kicking around the idea of a bronco meet-up.
Dave
Bronco now has 4wd. shortened the front driveshaft today, need to add gear oil to the front and go have fun somewhere.... ;D
Dave
