Post by onewyr on Apr 2, 2009 20:46:15 GMT -5
I swear everything I touched went to crap today I started welding the driver side rock rail in and on the last weld I ran out of argon/co2 so I said screw it I'm done and going inside then later I got the urge to go and pull the leaf springs so I could remove one of the leafs to try and lower the rear end and I pulled the center pins to separate the leafs and stripped both center pins so now I have 2 leaf packs laying on the ground waiting for me to grab another set of pins from SPRING MENDERS and also gonna get my bottle refilled at ARCET tomorrow so maybe I can get this truck finished up this weekend, or at least get it to where I can drive the thing with out dodging the cops, maybe take a test run over to deepcreek Whats left
1. Mount the rear shocks
2. finish and mount the bed
3. rework the floor pan around shifters and extend shifter 4. install rear and side glass 5. prep and paint body 6. install passenger side rock rail
7. install reduced leaf pack and check height 8. install tanks for OBA and plumb 9. wire cooling fan 10. install tunes
11. wire tail lights 12. fix the recline levers on seats 13. alignment 14. put trim on windshield 15. mount tow points to rear bumper 16. add hitch receiver to front and rear bumper 17. oh yeah and finish
Post by onewyr on Apr 3, 2009 19:26:37 GMT -5
I picked up the center pins and refilled the bottle today and then went and watched Fast and furious it was a pretty good flick there will be another sequel. But anyways back on topic. I re-assembled the spring packs minus 1 leaf and now with the bed on the truck the bottom of the bumper is set at 30 inches so I figure by the time I get a full tank of fuel, the spare tire, and my air tanks it should be sitting right where it needs to be. I decided I am just gonna frame around the gas tank so that I don't lose so much of the bed space
Post by LILREDCJ6 on Apr 3, 2009 20:13:28 GMT -5
Where's the BABY SEAT mount?
Oh and you got a hole in your bed.
Post by onewyr on Apr 3, 2009 20:15:19 GMT -5
thank you captain obvious. figure I will make a hitch mount for her car seat
Post by LILREDCJ6 on Apr 4, 2009 7:01:52 GMT -5
whats with the jeep in the yard? We finally convert you?
Post by jeeepxj on Apr 4, 2009 7:33:56 GMT -5
Is that Jimmy's piece?
Post by onewyr on Apr 4, 2009 18:30:41 GMT -5
yes that is jimmy's piece.
I got the bed mounts made and mounted the bed I also got the case shifter extended and floor plate cut and re installed now I just need to put the glass in and put all the floor plugs in so I don't suffocate. After dinner at Rancho Grande Me, Brandy,and Jaxon got the tail lights all working. Brandy was operating the pedals and switches while Jaxon handed me tools so I could splice the wires back together. Tomorrow I will get the fan hooked back up and hopefully get the passenger side rockrail mounted then I will start the long task of grinding the bed down and get it ready for paint.
