Post by onewyr on Nov 21, 2008 22:13:07 GMT -5
Well I finally got another truck and here are the stats 1992 STX extended cab 4.0 M5OD stuff that needs to be done paint new door (my fault) valve cover gasket PS pump transfer case no worky things I plan to do Get my bronco back and rob all the goodies from it and put them on the ranger but take that 4" skyjacker kit up to 6" add some extended radius arms strip the interior and bed line the inside new seats
Post by Deleted on Nov 21, 2008 23:09:04 GMT -5
Looks like a neat platform for a build Bryan. Do is the going to be dual purpose, or a trailer rig? Oh, and love the ladder rack.
Post by onewyr on Nov 21, 2008 23:24:11 GMT -5
dual purpose I can't really afford a tow rig so I gotta go dual purpose. and the ladder rack and tool box have already been removed as well as the door. I will get a couple pictures of the door tomorrow I gotta let the digi cam charge up
Post by onewyr on Nov 22, 2008 19:52:25 GMT -5
things I got done today removed the bed,rear bumper, and trailer hitch sanded and primed the roof I gutted the interior
Tomorrow I plan on pulling the dash because there is a very bad leak coming from the window causing some little green monsters (corrosion) to wreak havoc on the wiring so I am gonna take out the dash and try to salvage the wiring.
Post by onewyr on Nov 23, 2008 16:14:30 GMT -5
For those of you that saw my other thread about tearing up my driverside door in the garage here are a couple pictures after I tried to bend it back but as you can see it didn't work. and here are a couple of what I got done yesterday. I didn't get anything else done except for trying to figure out how to shorten the wheelbase and I think I got it just need a welder now.
Post by Deleted on Nov 23, 2008 21:50:42 GMT -5
I did the same thing to an '81 F250's driver's door. How I didn't break the glass is beyond me.
Post by onewyr on Nov 23, 2008 22:12:55 GMT -5
I know why I didn't break my glass it was rolled down and all the damage was on the top of the door
Post by onewyr on Nov 26, 2008 20:18:20 GMT -5
Today after work I made some good progress. I got the dash removed, I cut the front clip off to make room for the older front clip like I did on the broncoII, I unbolted the drive shaft and unplugged the harness to the tranny and transfer case, I am planning on pulling the motor/tranny/tcase but that will have to wait till friday morning, I am gonna head down to PNP and find a 4.0 with the lift hooks because my motor doesn't have any on it, after I get the motor out I plan on getting my buddy to go through the motor for me cause it leaks a whole lot of oil and I want him to see if the motor is damaged from lack of water. While the trans is out I plan on cracking the case and flushing the inside out because the shifter bushings are non existing so the parts had to go somewhere. On friday the windshield will also be pulled while the glass guy is replacing my brothers windshield I will have a new windshield installed after I paint the cab. I will get some pics of the progress tomorrow
Post by onewyr on Nov 27, 2008 10:55:02 GMT -5
Post by jim89yj on Nov 27, 2008 15:08:13 GMT -5
You know that it looks like a chop shop got ahold of your truck
Post by onewyr on Nov 27, 2008 19:54:35 GMT -5
I got the motor pulled tonight I just need to get it on the engine stand and out of the way. I still need to get the trans and tcase out but That will probably have to wait a couple of days I gotta get some of the carnage out of my garage so I can work on my brothers RX8 tomorrow if the parts come in. Hopefully by the end of the weekend I can get the rest of the junk out from under the truck and then I can start prepping the body. I got a pretty cool paint scheme in mind I even plan on using an acctual paint gun instead of rattle cans hahahahaha
Post by onewyr on Nov 28, 2008 18:44:02 GMT -5
Post by onewyr on Nov 30, 2008 19:28:20 GMT -5
all I did today was soak the frame in krudkutter and then pressure washed everything. While doing this I uncovered some cancer it started on the crossmember right under the back of the cab and the frame hase some rough scales but I think if I get the crossmember which has about a dime sized hole out I can treat the frame and probably go ahead and plate it in that area. In order for me to pull that crossmember I need to remove the cab this will also allow me to inspect the rest of the frame more in depth. I am gonna have to call on some of my buddies to lift the cab off of the frame, any volunteers?
Post by Marshall on Nov 30, 2008 19:40:13 GMT -5
When do you wanna get pulled? I can give you a hand..
Bryan
Post by onewyr on Nov 30, 2008 19:48:39 GMT -5
as soon as I can get a few guys together I need to build a cart to set the cab on so I can move it around in the garage how much do you think an extended cab weights
