Post by toynrnd on Jan 30, 2009 11:24:55 GMT -5
You know you will only be 2.5 hours from Tellico. I say flat tow the Jeep, pick up the trailer, then go wheeling.
Post by Deleted on Jan 30, 2009 11:26:31 GMT -5
You know you will only be 2.5 hours from Tellico. I say flat tow the Jeep, pick up the trailer, then go wheeling. I am looking in to that, but I am under the impression it is all closed until April.
Post by Deleted on Jan 30, 2009 11:34:04 GMT -5
Post by toynrnd on Jan 30, 2009 11:34:31 GMT -5
Post by rousch6 on Jan 31, 2009 5:04:21 GMT -5
Dont give him any ideas ;-)
Post by FJ40Fran on Jan 31, 2009 23:31:16 GMT -5
Keith. looks like the link is gone. So what are the details on this trailer? Fran
Post by Deleted on Feb 1, 2009 0:45:06 GMT -5
Post by FJ40Fran on Feb 2, 2009 21:23:43 GMT -5
Keith, pretty nice trailer, nice axles. G rated tires are the way to go, but you'll not like it when replacements are due. As it sits, I think the front is cranked up pretty good, explains the rear squat. It should level out nicely. I find interesting the framing design, this one has exterior C-channel (10 in?) with C-channel crossmembers. I wonder how much body twist there is when you get on uneven ground. I remember a selling point from Kauffman was that they run a 4x4 square tube the center length of the flatbed, acting as a tortion bar. Maybe it's not a huge deal, but they made it a point to me. All said, looks like a nice trailer, at least running nice axles and tires.
So, did you make it home with it today?
Fran
Post by toynrnd on Feb 2, 2009 21:30:04 GMT -5
I have a good place to get G rated tars...Hampton Roads Tire Service on Military Highway.
Post by FJ40Fran on Feb 2, 2009 21:49:37 GMT -5
When the day comes, I plan to upgrade my 'E' - rated China made tires. Pretty impressive when one blows loaded at 65-70 mph. Fortunately, that's only happened once in the last four years.
Post by Deleted on Feb 2, 2009 22:17:34 GMT -5
So, did you make it home with it today? Fran I did, it's been a long day. Left at 7 got home at 9:30 tonight. So far so good. There is some twist in it while empty. It appears that it wants a load on it, as it would stiffen it up if that makes sense. 2 of the tires are a little flat spotted and worn, so eventually I'll need a couple replacements. I can get by for a while though. Chris, how much are they? I came home with a little bit of extra cash because the brakes aren't working as he said. They're on there, and look ok, but there's a break in the wiring somewhere; my controller can sense if there's a connection or not, and it's not getting one. There's some kind of box mounted on the tongue that the main harness goes in to, then another harness comes out and goes to all the lights. Not sure what that is or if it has anything to do with it, never seen one before. The toolbox is nice, but it needs some reinforcement, it's bolted through the back down low and it's trying to twist forward at the top and pull the bolts through. Easy fix.
Post by FJ40Fran on Feb 2, 2009 22:24:57 GMT -5
Welcome to the gooseneck ranks...!!!! ;D ;D Now when is the first run to Crozet so you can practice narrow roads and tight manuevers, or going up to Gore has a nice narrow road too. You know towing to Oakridge doesn't count with all the wide nice space... lol. Look forward to seeing it, maybe have to stop on the way home from work to check it out. Fran
Post by Deleted on Feb 2, 2009 22:39:00 GMT -5
Sure! Feel free, weather permitting I'll be out there with my test light and soldering iron. I figure I have 3 days before I have to take it to Ed's or I'll get my nice HOA letter.
Post by LILREDCJ6 on Feb 2, 2009 23:02:57 GMT -5
yeah but, they have to give you 30 days to move it. Trust me i pushed the limits on there times just because i could.
Nice trailer by the way
Post by Deleted on Feb 2, 2009 23:12:14 GMT -5
So, did you make it home with it today? Fran I came home with a little bit of extra cash because the brakes aren't working as he said. They're on there, and look ok, but there's a break in the wiring somewhere; my controller can sense if there's a connection or not, and it's not getting one. There's some kind of box mounted on the tongue that the main harness goes in to, then another harness comes out and goes to all the lights. Not sure what that is or if it has anything to do with it, never seen one before. Could it be a break-away kit? Is there a stranded wire with a pull out thingy?
