Post by CORE 4WD on Jan 7, 2006 15:33:01 GMT -5
Axle is done, ready to go back in- Had to go back and re-braze air line to seal housing-nice job Jim! That did the trick, air check good. Alex getting his fix on! Making new frame insert for t-case skidplate, probably not quite as strong as factory insert which "sandwiches" the frame so I'll have to check it again after a couple trail rides- Ok, Jay r u ready to install? Axle needs installed and t-case skid need installed to measure for rear driveshaft length. Tomorrow is supposed to be nice! ;D
Post by RuffRider on Jan 7, 2006 16:18:59 GMT -5
Great lookin stuff, Dave and Jim... I will be off sunday, just gimme a call when your ready to wrench...
Post by Jim63 on Jan 7, 2006 19:01:36 GMT -5
hey that was a lot of fun guys!! And jay thanks for providing the learning material ;D
Post by RuffRider on Jan 7, 2006 19:06:47 GMT -5
Yeah, this school is almost over...
Post by Jim63 on Jan 7, 2006 19:13:51 GMT -5
yep!! I bet you cant wait
Post by RuffRider on Jan 7, 2006 19:17:39 GMT -5
Yeah and I don't want Dave to have to put a bed in the garage...
Post by CORE 4WD on Jan 7, 2006 20:35:24 GMT -5
When the SYE comes in make sure you come over to check that out! It's pretty fun to do, compared to pulling a carrier (like an 8.8!) a few hundred times! Got a bunch done today- Can you tell Jay's excited? Lining up lower mount- Thanks for dropping by Billy- Track bar mount- Torquing everything- Almost a complete jeep again! Going to lose the t-case drop with SYE install as well-
Post by RuffRider on Jan 8, 2006 21:03:43 GMT -5
I am really excited. Real close to finish. Dave, I can't thank you enough. It looks awesome. Great job... And Jim, you helped out every step of the way, thank you and have a safe trip back to school..
Post by Chele on Jan 8, 2006 21:12:13 GMT -5
Looks NICE...I can't wait. I'm so sad that you won't be there this weekend!
Post by RuffRider on Jan 8, 2006 21:19:57 GMT -5
Well, I still don't have driveshafts in to turn those nice NEW axles. If the trip was next week, maybe I would've made it. But knowing how long it took for e'erything to arrive, I dread to see how long it takes the driveshaft and sye to come...
Post by Jim63 on Jan 8, 2006 23:20:39 GMT -5
that looks great! Im glad I was there to help out during the build up! Are all the other parts ordered?
Post by RuffRider on Jan 8, 2006 23:27:26 GMT -5
Didn't leave Daves' until almost 7... I'll order in da' morn.. So it'll be here in the near future.
Post by Jim63 on Jan 8, 2006 23:46:35 GMT -5
sweet!!
Post by RuffRider on Jan 9, 2006 0:00:17 GMT -5
Tom Woods has stuff(sye & driveshaft). After that eliminates t/c drop so I Need stock skid plates bolts, as mine will now be too long Anyone have any they don't need anymore? I think a belly up will be in my future(core4wd design)..
Post by CORE 4WD on Jan 9, 2006 11:52:09 GMT -5
Your bolts are specific to the skid you've got on there. At least all the ones I've had down have had regular bolt heads as in countersink heads so the stockers, which are regular bolts, won't work unless I make up some adapters. (I would just cut threads all the way up bolt but I don't have a die the right size.) Bolt also has to have no shoulder, needs to be all thread. Can someone with (preferably) 2000 TJ check for style of bolt head on their stock t-case skid plate? The ones that go to frame rail. Thanks in advance...
